Volume up/down and Total Commander
AndaK
Post by AndaK » Aug 25th, ’17, 18:26
Hi again
First I want to thank you Marko fr the help with the unreg; it seems defininately solved. :)
Now my question. I change volume settings with the command Send {Volume_Up 1} (and /down) on + and - of numeric keypad
and works fine except when Total Commander window is up. Then I get a TC window for 'expand selection' or 'shrink selection'.
Extensive search around the net but haven't been able to solve it.
Do you have a suggesion for me?
thanks
Angel
Post by Marko » Aug 26th, ’17, 23:48
I tested your shortcuts in Total Commander, latest version 32bit and it works as expected - Numpad +/- control the volume in all cases. Are you using any Total Commander add-ons?
AndaK
Post by AndaK » Aug 30th, ’17, 13:05
Yes Marko,I do have one. DiskDirExtended wcx x64; creates a list file with all selected files and directories, including subdirs - but also lists contents of archive files.
Afaik it worked before with this extension. Have tried a fresh install of Total Commander but I get the same result.
https://i.imgur.com/WtqGwsF.png
And found this: https://shortcutworld.com/en/Total-Commander/8/win/all
[edit]
I've asked on TC forum and it's solved now. TC was running in admin mode which seem to have caused the problem. Thanks for help Marko.
/regards
Angel
