traughber
Post
by traughber » May 23rd, ’17, 20:20
When I try to use the following as a Text Expander replacement
SELECT
Field1
,Field2
,Field3
FROM Table
WHERE 1=1
I get the following:
SELECT
Field1
,Field2
,Field3
FROM Table
WHERE 1=1
So it's not handling the tabs correctly. I also tried using spaces in the replacement instead of tabs and I get the same result.
traughber
Post
by traughber » May 23rd, ’17, 21:20
I also tried using {Tab} as well. Same result.
Post
by Marko » May 23rd, ’17, 23:53
This depends on you editor settings. FastKeys sends text exactly as you would type it. If your editor is set to use auto indents, the result can be different. To avoid this you may send text using clipboard - set option Text Expander/Advanced/Use clipboard if text length exceeds... to lower value (1).
