Dropdown key/value pair
aukseller
Post by aukseller » May 11th, ’17, 12:54
Would it be possible to use key value pairs in dropdowns, listbox, and combobox controls? In other words, associate a long text string with a unique key string, which is the part that get's displayed in the dropdown?
Something like...
Example 1|This is example 1 and contains a much longer phrase than is ideal for displaying in a dropdown, perhaps even with formatting i.e. {Space}, {Enter}, etc
Example 2|Hopefully you get the idea and it's something that is either already possible or could easily be implemented?
Example 3|Example 3 etc
Post by Marko » May 11th, ’17, 21:52
This is possible by using Description separator.
http://fastkeysautomation.com/forum/vie ... ?f=3&t=535
aukseller
Post by aukseller » May 15th, ’17, 16:53
Thanks very much, that will do the trick!
