diego6111
Post
by diego6111 » Feb 16th, ’17, 23:17
Marko wrote:
We can implement * suffix instead of prefix. Typing "java*" would show all strings and descriptions containing word "java".
That would work very well for me.
It's very similar to “Include words containing the string” in functionality but the user can control exactly when to use it.
Thanks for considering it.
Post
by Marko » Feb 21st, ’17, 23:35
This was implemented in v3.17. Please let me know how it works for you.
diego6111
Post
by diego6111 » Mar 1st, ’17, 11:53
Sorry for the late reply. I could test it properly only today.
The option doesn't seem to work for me.
If I uncheck “Include words containing the string” and check only “Include descriptions” the expected behavior (search descriptions only after suffix is typed) does not occur.
If I type “java*” nothing happens.
If I check both “Include words containing the string” and “Include descriptions”, the menu appears as soon as I type “java”, even before the suffix (*).
I don't know exactly how the feature was implemented so maybe I'm doing something wrong.
Thank you.
Post
by Marko » Mar 5th, ’17, 16:37
This feature should only work when "Include similar words (smart search)" is disabled. Can you please verify?
diego6111
Post
by diego6111 » Mar 12th, ’17, 11:36
I tested it again and it doesn't work here (even version 3.18). I tried several configurations options. I will test it in another computer just in case there's something installed here interfering with Fastkeys.
Post
by Marko » Mar 14th, ’17, 23:08
It works for me. Typing Java*, a suggestion appears after pressing *.
Display suggestions as you type - Enabled
Smart search - Disabled
Include words containing the string - Enabled
Include descriptions - Disabled
English Common Words wordlist - Disabled
