The clipboard manager is great. It would be even better if users had the option to assign preferred sounds to play when an item has been captured to the clipboard. Also helpful would be a separate sound to indicate that a duplicate item has been captured.
I used ClipCache in the past, which has this feature - see screenshot of ClipCache sound setting below.
Thanks for considering this suggestion!
Clipboard Mgr. - Play Sound on Cut, Copy & Paste
Thanks for your suggestions, this may be considered for one of the next versions.
