Special Character With Additional Character
Archivist
Post by Archivist » Mar 2nd, ’18, 15:29
If I paste the copyright character into a new phrase
Phrase express sticks a letter right after it in the phrase
®e
If I delete it it shows right back up.
Post by Marko » Mar 2nd, ’18, 17:59
You have a substitute set as ®e.
Are you mixing FastKeys with some other software?
Archivist
Post by Archivist » Mar 2nd, ’18, 19:29
I don't think so. I used to have phrase express but I unstalled it. Let me shut everything else down and see if something else is causing it.
Post by Marko » Mar 2nd, ’18, 21:04
As I said, check the setting - you have a substitute set as ®e.
Archivist
Post by Archivist » Mar 2nd, ’18, 21:30
Thanks! Fixed.
