Newbie with an question about exclamation points
onebeanshy
Post by onebeanshy » Feb 4th, ’18, 19:10
Hi! I just purchased Fastkeys and am coming across an issue. In Text Expander, I have a few substituted phrases that end in multiple exclamation points. It seems any more than 1 exclamation point in the phrase will remove all exclamation points. Is there a way around this?
Current behavior:
Testing! will show up as Testing!
Testing!!!! will show up as Testing
Expected behavior:
Testing!!!! will show up as Testing!!!!
Thank you!
Post by Marko » Feb 4th, ’18, 21:52
The following characters have a special meaning in FastKeys:
^ - Ctrl key,
! - Alt key,
+ - Shift key,
# - Win key.
This allows sending not only text but also other actions. To send those characters you need to select Send Raw Text option or enclose them in braces, like {^}, {!}, {+}, {#}.
In your case
Testing{!}{!}{!}{!}
onebeanshy
Post by onebeanshy » Feb 5th, ’18, 16:07
Perfect, thank you so much!
