Hi - when I'm trying to remap Right Windows Key to the other key, it still runs a command of LWin.
Please help how to solve this.
Thanks.
Remapping RWin in Win10
Win key is a modifier so this requires a little trick. Double click on a Shortcut field and enter the following:
~RWin
Then enter the other key into the command field.
~RWin
Hi Marko - thanks for the tip, but it still doesn't work. :-/
I'd like to have eg. ScrollLock key to act as {RWin} - when I press ScrollLock the {RWin} menu should pop out (now it act as {LWin}).
How to achieve this?
The same effect has Mouse Right Button, but i need to open {RButton} on the place where I work, not at the mouse cursor position...
Thanks in advance.
Thanks in advance.
Your example (on posted image) works well on my computer - ScrollLock openes Windows Start menu. On my keyboard, left and right Win key have the same function.
Yep, it opens LWin menu, RWin has different function (like right mouse on selected menu item).
Is it possible to have this functionality (map RWin to other key)?
Thanks.
Thanks.
Left and right Windows keys normally have identical functionality. I think you are confusing Windows key with the Menu key (or Apps key).
To assign this key select ... button and select AppsKey from Standard list.
