JGM22
Post
by JGM22 » Jan 4th, ’18, 20:00
Even though FK is paused ( ctrl 2 ), when I type ping then press the spacebar it activates the script.
String ping
Description ping
Type Send
Substitute ping -a %INPUT_Client%{Enter}
Post
by Marko » Jan 4th, ’18, 21:23
It works as expected on my computer. Do you see a red FastKeys icon when paused?
JGM22
Post
by JGM22 » Jan 5th, ’18, 13:07
Yes, the FK icon is red. I think the issue is when I have FK running and forget it is running and run a ping I then disable FK but ping seems to still be in memory. Still playing around to determine the exact steps.
