Special Character Question
Archivist
Post by Archivist » Dec 13th, ’17, 16:08
When I create a Text Expander for the bullet point character (•) I get really weird behavior:
1. it removes the description;
2. it acts as if I've checked Don't Delete string;
Is there a special way I'm supposed to enter special characters
Post by Marko » Dec 13th, ’17, 17:54
Can you please post your exact setting of abbreviation and substitute?
Archivist
Post by Archivist » Dec 13th, ’17, 18:29
Here's what it looks like. It works fine for a while and then starts to get squirrley (e.g., blanks out the description and text)
Post by Marko » Dec 13th, ’17, 19:14
Thanks, the problem is with using "•" character in the description. Please change description until we solve this.
