autocomplete save file location transfer and .fdb
NomNOm
Post by NomNOm » Dec 4th, ’17, 12:22
Hello Marko,
I saved my .fdb file in dropbox.
Am I correct that saving the .fdb does not include the autocomplete txt file along with it?
if its not, any suggestion on how I can change the save location of the txt file.
Noms
Post by Marko » Dec 4th, ’17, 18:50
fdb file does not include Phrase files or Wordlists. You can simply copy your files to your Dropbox location and then change their path definition - select Open button to select your new path.
