hotkey to bring up FastKeys main window
jrwf555
Post by jrwf555 » Nov 25th, ’17, 05:35
If Fastkeys is running but hidden in the taskbar, is there a hotkey that can bring up the main window? This is so that it's possible to add new items, phrases etc. Of course, it's always possible simply to click the icon in the taskbar/notification area, but since FastKeys is all about hotkeys....
John
Post by Marko » Nov 25th, ’17, 07:03
Yes, you can set a Settings shortcut in Preferences/General/Shortcuts.
jrwf555
Post by jrwf555 » Nov 25th, ’17, 20:25
Thanks. I should have been more specific. I'm not sure how to set up the command once I get to Preferences/General/Shortcuts
Post by Marko » Nov 26th, ’17, 17:10
I'm not sure I understand... in Preferences select General/Shortcuts tab. Then select Setting shortcut field and press desired key combination on your keyboard.
jrwf555
Post by jrwf555 » Nov 26th, ’17, 18:22
Your last post solved the problem. I didn't realise you needed to select Setting shortcut field in Preferences/General/Shortcuts and was a bit bewildered by what the various fields meant this area.
(For instance, what 'Quick-add' does - actually, what does 'Quick-add' do? I couldn't give it a function whatever key I allocated).
But bringing up the Settings window is all sorted. Thanks again.
Post by Marko » Nov 26th, ’17, 21:41
Quick-add shortcut can be used to quickly use the selected text, file, folder, webpage or command code to create a new FastKeys command item. ;)
jrwf555
Post by jrwf555 » Nov 27th, ’17, 00:52
thanks
