Since updating to the latest version of FastKeys ( 4.04 ). I noticed that if I put dots one after another:
It'll trigger the autocomplete, even if there's no string that matches that criteria. Here's the current configuration:
https://gyazo.com/07dbcb8b41b91fea143f73411d7718a1
Any suggestions?
Auto Complete bug?
I happened to have the installer from the previous version ( 4.03 ) and the issue stopped happening. So it's definitely related to the new version.
I cannot reproduce this. What is the popup suggestion showing?
What are your calculator settings (Preferences/Functions/Calculator)?
I don't have any calculator settings, here's the screenshot of my configuration window.
https://i.gyazo.com/2585efe3afcbcfd845d ... 650495.png
Basically what happens after upgrading to the latest version is that if I put those two periods one after the other it'll match everything in my auto-complete list. Like it's a wildcard in regular expressions.
Your screenshot is from previous version, please check the recent one.
You can also send your settings.fdb and settings.ini file to our support mail to see what might cause your issue.
