Export each stored script as independent text files?
smallabc001
Post by smallabc001 » Oct 8th, ’17, 10:53
I want to backup those written scripts stored in "Menu".
However, instead of backing everything up as a single *.fdb file, is it possible to export each written "Menu Item" as independent text file also, since I would like to create a archive directory for each written script.
Post by Marko » Oct 9th, ’17, 21:39
This is currently not possible. Wouldn't it be easier to just copy and paste the scripts to a text file?
smallabc001
Post by smallabc001 » Oct 10th, ’17, 04:25
Yes. But only after writing >20+ scripts in FastKeys do I realize the need to save them independently as text files.
The reason is that, sometimes I need to access these codes from computers without FastKeys installed. That's why I plan to upload these text files onto a cloud drive and have them accessed via text file format.
Post by Marko » Oct 10th, ’17, 13:12
I understand. My point was that it probably takes the same time to open each item, select all, copy and paste to your text file (comparing to selecting each item and selecting menu to export to file etc.).
