Open Home Directory (using environment variables)
Archivist
Post by Archivist » Oct 5th, ’17, 17:32
An OPEN version of the command %USERPROFILE% doesn't do anything.
I have a cludgy version w/ a run command
cmd.exe /k explorer C:\Users\%USERNAME% & exit
Is there a correct way to do it.
Post by Marko » Oct 5th, ’17, 21:43
This should work:
cmd.exe /k explorer C:\Users\%A_UserName% & exit
Archivist
Post by Archivist » Oct 5th, ’17, 22:12
Perfect.
This also works
explorer.exe "C:\Users\%A_UserName%\Google Drive"
