Text-expansion with Chinese characters?
smallabc001
Post by smallabc001 » Sep 27th, ’17, 08:56
I tried inputting chinese words like "一" to text-trigger "一二三四五六七八九十"
But it seems text expansion is only workable for english letters.
Is it possible to configure to use Chinese words as trigger as well?
THanks!
Post by Marko » Sep 27th, ’17, 13:24
Text expander in principle work by monitoring keyboard events. Could you try changing your keyboard setting?
Which keyboard, language and input settings do you use?
smallabc001
Post by smallabc001 » Sep 27th, ’17, 13:36
Hi Marko, thanks for your reply.
I am a novice user. How should I adjust for the keyboard setting?
My default PC language is "Traditional Chinese" .
I usually use "Microsoft ChangJie 10.1 " mode to input Chinese characters.
After that, I will switch to default "American English" keymode to type English.
Thanks a lot!
Post by Marko » Sep 27th, ’17, 14:23
Input made by virtual keyboard will not work.
When entering the String in the Text Expander definition, try to use another (direct) keyboard. I tried with English and this works for me:
String: one (change to your abbreviation)
Substitute: 一二三四五六七八九十
smallabc001
Post by smallabc001 » Sep 28th, ’17, 04:53
Thanks a lot!
