Use a Fastkey in a Fastkey %input% line
EricG
Post by EricG » Sep 22nd, ’17, 21:55
Is there a way to use a fastkey within a fastkey input for example if the input was %INPUT_Day% and I set up a "fr" fastkey for friday can I use the "fr" without the input window? Thanks.
- Eric
Post by Marko » Sep 22nd, ’17, 21:56
When entering Input or selection fields, the regular text expander and shortcut items are disabled to prevent potential conflicts.
Not sure if I understand you question correctly...
EricG
Post by EricG » Sep 22nd, ’17, 21:56
That answers it. I wanted to use a text expander in a input field. thanks.I understand why it would be disabled.
